Thanks in advance,
One of my friends is planning on building a new computer. Here is what he has so far:
CD / DVD Drives
2x NEC Black IDE DVD Burner Model ND-3540A - OEM
Price: $81.98
http://www.newegg.com/Product/Product.asp?Item=N82E16827152047
RAM
Crucial Ballistix 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 500 (PC 4000)
Price: $296.00
htp://www.newegg.com/Product/Product.asp?Item=N82E16820146578
Power Supply
SeaSonic S12-600 ATX12V 600W Power Supply
Price: $159.00
http://www.newegg.com/Product/Product.asp?Item=N82E16817151025
Processor
AMD Athlon 64 X2 4400+ 1GHz FSB Socket 939 Dual Core Processor
Price: $497.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103546
OR
AMD Athlon 64 X2 3800+ 1GHz FSB Socket 939 Dual Core Processor
Price: $322.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103562
Case
Lian Li PC-61 USB Black Computer Case
Price: $110.00
http://www.newegg.com/Product/Product.asp?Item=N82E16811112025
Motherboard
DFI LANPARTY UT nF4 SLI-DR ATX AMD Motherboard
Price: $163.00
http://www.newegg.com/Product/Product.asp?Item=N82E16813136157
Hard Drive
Western Digital Caviar RE 320GB 3.5" Serial ATA150 Hard Drive - OEM
Price: $145.00
http://www.newegg.com/Product/Product.asp?Item=N82E16822144407
Video Card
eVGA Geforce 7800GT 256-P2-N517-AX Video Card
Price: $349.00
http://www.newegg.com/Product/Product.asp?Item=N82E16814130249
Heatsink
ZALMAN CNPS7000B-Cu LED 2 Ball Blue LED Light Cooling Fan
Price: $38.99
http://www.newegg.com/Product/Product.asp?Item=N82E16835118119
Do you think he'll need more cooling? Which processor do you believe will be more beneficial in the long run? He plans on using this computer for the next 2-3 years as his 2800AMD build has lasted him quite some time. He's just looking for an upgrade...hopefully under $2000. Thanks again for you time, can't wait for the replies!
CD / DVD Drives
Price: $81.98
RAM
Price: $296.00
Power Supply
Price: $159.00
Processor
Price: $497.00
OR
Price: $322.00
Case
Price: $110.00
Motherboard
Price: $163.00
Hard Drive
Price: $145.00
Video Card
Price: $349.00
Heatsink
Price: $38.99
