Friend needs help with his 9250
Hate_Bot
He recently purchased a 9250 and whenever he plugs it into his cmputer, and plugs the monitor in, it doesnt turn on (The monitor) hes using the drivers that came in the box, Ive been trying to urge him to install SP2 (SO he can install the new drivers) and such. Do you know of any other problems that could have happened to it?
unless hes harrassing u endlessly and u owe him something dont help if u dont want to =P
check if the videocard is loose inside..might not be locked in
Tell him it might be the fact that he "recently" purchased a prehistoric card. Ok, it might not be that ancient, I just find it funny someone would buy a new vid card and go that old...
I just bought a 9250...
Z(+)DIAC said:
Oh, well in that case good for you
:rolleyes:
I can't afford much more, and I don't play too many games on my PC. It's a lot better then the onboard card I had.
Hate_Bot said:
Could have gotten a 9550 for like 20 more, a bit better, but still not good :p
Oh well :p Anyways, I believe you need to have SP2. I know I have it, and when reading about the 9250 installation, that you need SP2 to install the card.
