friend has a problem
vocab
Everygame he plays... multiplayer mostly he gets frame skips and its not smooth at all.He thinks its his pata hard drive slowing him down.What do you guys think it is?
His Specs Are
X2 4200+
Evga 7800 GTX
Asus SLI Deluxe
CORSAIR XMS 2 GB 2-2-2-5
What are the specs on his drive? What res/settings is he running at?
His rig should be able to handle anything he throws at it, as long as its properly set up.
im pretty sure its a 7200 rpm IDE drive. And settings doesnt really make a difference he gets frame lag in regular 1.6 cs.
I really do think he did something wrong.
WHy would a hard dirve slow you down during play? Disk speed ONLY affects load times, unless the prog is SWAPin out which isn't the case if he has 2gb.
Secondly you mention Multiplayer but you didnt even look into the network side of things?
He could:
A. Just have a shitty ping on that server (you are familiar with a ping, right?)
B. Network drivers or hardware could be bad.
C. High temps outside? Is this happening during the afternoon? (cable and DSL signal stregnth degrade with temperature)
a 7200 drive shouldn't slow it down unless there was something physically wrong with the drive. has he had issues with it in the past?
is this a fresh install? did he put the new parts in and keep the old OS on it? drivers up to date? error messages in eventvwr? dragged the HD?
purple_haze said:
try cl_smooth 0
in 1.6 it has no affect...like I said its all multiplayer games
Its a fresh install
brand new hard drive
drivers are up to date..except bios im sure
I for one think its his dsl for sure...ill talk to him later when he gets home.
thanks for the help
