fried USB +5v... using external source?
Flo
I accidentally fried the +5v power line to my old mainboard's (K7S5A) add-on USB headers. The ports still work, but only with self-powered devices. Bus powered devices don't work.
Is there anything "special" about the +5v power line that goes to the USB ports or could I just feed the +5v pins from a Molex to make the ports fully functional again?
I have a powered hub, I'd just like to be able to use bus-powered devices directly on those ports.
For the price of a powered hub or the K7S5A ... you'd be better off replacing those two, than whatever device it is you want to connect there ... but ... you can give it a shot, and tell us the result ... :D
Replacing the board would be the oft way to fix the problem ;)
using a generator powered by 3 starving gerbils would be the [H]ard way..... :D
but if you really want to use it i suggest just buy a new mobo....or upgrade....couldnt hurt :D
I just upgraded to an NF7-S 2.0 and put the K7S5A into another case to use as a tertiary machine. It's good enough for that as I don't do gaming on it. Might eventually replace it but for now it's doing just fine. Going to try the +5v mod today.
Seems to work fine. I removed the two pin1 cables from the connector and connected them directly to a +5v line from a molex. Booted up the computer and bus-powered devices are detected and working fine.
Good to hear ... I'll try to remember that ... :D
