Fried? Never fried a mobo before.
Steve_Oaks
Ill cut right to the chase. While booting I plugged in they keyboard. Computer died. Now the power supply will start to power the cpu fan for about 30 seconds then die. The computer does not start to boot. Replace the power supply and as soon as I put the power cord in the cpu fan comes on but no response when hitting the power button to start the computer. I have disconnected every non essensial thing. Board is an Asus a7n8x, bout two years old. Computer pretty much runs constant, only goes down for power outages and occasional reboot. Today was the first time it actually when down for a prolonged time, about an hour. Fried mobo? Is there a reliable way I can test the mobo?
PS/2. And before I plugged that in I plugged a usb mouse in, though I dont recall if I plugged the usb mouse in before I powered up or not.
Take the battery out for a while (an hour) and put it back in.
Be careful with the battery, I hear it's bad to get them dirty...
the best way would be to have another system and swap around parts till you can narrow it down..but i take it you don't have extra mobos, processors, RAM, video cards, and power supplies lying around? ><
I do. I just do not have another socket A mobo. Im quite sure its the mobo. I tried removing the battery for a minute and an actual cmos clear via jumper(obvously while the battery was in that is). Ill try leaving the battery out for awhile.
Take the mobo out of the case and run it with just the PSU, video card, RAM, and power switch attached.
You've fried the MOBO! It happened to me once. Some boards'll go along with it, some won't, even reputable ones. Sorry...... :(
