Fried my CPU !!!
Psyluche
Hi to all. New here and it's my first post...
I have an old Abit KR7A motherboard and last night my cpu fan died on me and my CPU fried to death :mad: :(
Checking the specification of my motherboard it's listed that I can install a CPU from 1500+ to 2100+ or any future 266Mhz socket A processor. Since those kind of CPU are rare on my part of the planet (I live in Québec, Canada) the closest thing that I found is an AMD XP-M 2500+. Can someone tell me if I can safely put this CPU on my mobo ???
Thanks a lot in advance for any help !
I looked up Abits site and theres no bios revisions i can see that would allow a 2500+, and i think those are 333 or 400FSB, whereas your board is 266 only. I would check ebay or post on the FS/FT forum here you are looking for a 2100+.
And I also want to ask, when a CPU gets grilled to death when the fan fails, does the mobo take any damage ??? If so, how can I tell ?
Thanks again.
Baking a CPU shouldn't cause any problems with your MB. Now, killing a powersupply on the otherhand... :)
look for burnt shit on MB.......oh yeah and plug it in to see of works...that is about it for seing if a motherboard is ok ;)
I am now pretty sure that the mobo is now problematic... Had all kind of error when I upgraded the CPU. Seg fault when trying to compile gentoo linux... APIC error. Memtest86 gave me all kinds of wierd error (test 5 and 8) even with lot's of tweak in the BIOS. Bought a new DIMM from Kingston, same shit.
Can I safely assume, with these kind of errors, that the mobo suffured damage when I grilled my CPU ???
Thanks again for your kind help.
Have a nice day :)
hmmm test 5 is typically for a bad dimm but its possible your MB memory controller has had it i guess
Sounds like it might be new system time for you. :( or :D depending on how you look at it. Build you a new Athlon 64 system. ;)
