It seems I killed my computer. I had recently upgraded to a new setup and I was going to take off the side panel to check and make sure everything was working correctly. I decided to leave the computer on (big mistake I guess) because I wanted to make sure my new CPU fan was running correctly and I wanted to be able to feel the heat level coming off of it. The computer had been upgraded about three days prior and had been running for 72 hours straight with not a single glitch. I had even played some Flight Simulator X and Call of Duty 4 on it. All components in the computer were still at their stock clock speeds and nothing was OC'd yet.
As I removed the side panel the computer just powered down. I think there might have been a "pop" sound, but that could've also been my speakers reacting to their loss of input from the computer like they usually do when I shut down. I didn't see or smell anything yet so I tried to restart and of course the fans spun up and the lights came on, but no post or even so much as a blip from my motherboard....crap. Then I started smelling burning electronics so I quickly killed the PSU and pulled the plug.
I took all the parts out examined them, tried to isolate the issue and eventually determined that the most likely problem was the voltage regulators on my 8600GTS had blown out. The regulators were very slightly deformed (melted I think) and the 4-pin Molex had a little black burn mark on one corner of the connector. My motherboard, CPU, and video card were all determined to have been claimed by the incident (after testing the parts in a different computer) however my 2 SATA HDDs, my audio card, my DVD/CD drive, AND PSU all remained intact and are still in use (I reinstalled the components I had before the upgrade).
My question is:
What do you think caused this to happen? It was suggested to me that I might have touched a cable as I removed the side panel and that caused something to short circuit, but I was very careful to remove the panel straight upward and then out away from the case so that I didn't bump anything. I have a hard time believing this was the issue (especially when all cables are insulated and can be touched anyway). I also read somewhere that someone had a motherboard (not my make or model) that had some CPU backplate issue that caused a short because it was contacting with the case, I'm curious if something like this may have happened. The other reason I could think of was maybe I had an underpowered PSU, though my computer was just idling when I decided to remove the panel. Okay, well that's the whole story, lemme know what you think.
My system specs at time of death:
MSI 790GX Platinum
AMD Phenom 9950
Corsair Dominator DDR2 1066 2GB x 2 (4GB)
eVGA NVIDIA Geforce 8600GTS
2 SATA HDDs
1 IDE DVD/CD+-R/RW
M-Audio Revolution 7.1 PCI sound card
8 USB devices totaling about 600mA draw
Antec Truepower 550W PSU (about 2.7 years old)
*EDIT* Fixed typos.
My question is:
MSI 790GX Platinum
AMD Phenom 9950
2 SATA HDDs
1 IDE DVD/CD+-R/RW
*EDIT* Fixed typos.
