Fried Mobo?
HotGore
I got my new video card today so I popped it in my evga 680i motherboard, started it up, and all I saw was a blank screen. I checked the card and it wasn't seated properly (Thank you giant zalman chipset cooler.) I seated properly this time, now it will not boot at all. Tried my old 7800, and nothing. Only thing that is on is the little blue LED on the motherboard. I have tried swapping my ram, and sound card as well. From what I can tell it is fried, unless you guys have a better idea. I have 2 questions, is there a way in which to bring my mobo from the dead, and if not what is a killer mobo with passive cooling? Having SLI is not a issue.
you remember to reconnect the pcie power eachtime? tried resetting cmos? sure there's no shorting out anywhere? what if you pull all your ram and try to start the system. will it beep?
That light means that it's recieving power. Make sure it's grounded, and that there is nothing shorting the mobo. Check your standoffs, make sure they are secure, and the motherboard secured to it.
The posibility of a static discharge is there, unless your were grounded.
If you reseat everything, and nothing works, more than likely you are looking at an RMA.
Good luck man,
Chris
Made sure about the PCI-E power, reset CMOS, and tripled checked everything. Only thing left to do is pull everything out.
EDIT: alright looks like a dead mobo. Going to get a new mobo that isn't a POS.
how do you figure the mainboard is a piece of shit after you bricked it by cocking your vid card? do you think there are other motherboards available that are more idiot proof? sorry. no mattert which mainboard you do that to, you will get same result.
Well considering I got this motherboard very early on, and had fun with all the BIOS issues, that it wouldn't start randomly once, then the next day it starts up again, and that it has horribly loud stock cooling is part of way I hate this motherboard. Also I have seen a lot of video cards that where not seated right and not once did it fry the mobo.
well ok then. these mainboards are manufactured to a completely different set of tolerances than any other being built. i guess that pretty much sums it up. even tho damn near every mainboard built is using pcie slots built exactly the same by the same nanufacturers. it had nothing to do with your "giant zalman chipset cooler". and i guess this "giant zalman chipset cooler" didnt cure the "horribly loud stock cooling", even tho my particular boards (i thought they were like the other ones for some reason) had passive cooling. you must have really sensitive ears, matey, if the sound of heat coming off a passive radiator sounds horribly loud to you. the sound of paint drying and plants growing must be sheer hell . can you hear what i am thinking from over there? btw by any chance was this the video card that you yanked the capacitor off of?
You are supposed to use the fan when you OC.
Also stop thinking dirty thoughts, they are way too loud. :D
