Fried mobo, ram or both?
[H]ymae
OK
I bought 512mb kingston ddr 333 to go into my gigabyte ga7-vrxp, already had 512 of samsung. I put the aluminum heat spreader on and installed the dimm, when i plugged it in a booted up, smelled a funny smell, and 3 long beeps from the board w/ no display. turned power off and went with the original samsung dimm, still get the beep sound, moved them to different slots and everything. did i cook the ram, mobo or both?
three beeps mean something is wrong with ram normally.
Id say you fried both sticks at least.
though its possible the motherboard too...
you will need a good stick of ram to confirm this.
look in mobo manual to see what 3 beeps means. it's different depending on which bios your mobo uses.
the cool part is my mobo booklet has no listed beep codes.... more agro by the minute
