standalone installer for latest version*Web viewers and programs (Java, flash, shockwave, Acrobloat, etc)
I gotta wonder what purpose these types of threads serve as they basically turn into "Ok, let's say you do a clean install, what do you do in terms of software/drivers after the OS is installed?" type of discussion.
I mean, I understand people making suggestions but aside from "install the OS and update the drivers" the rest of it is going to be personal opinions on stuff that don't really help the OP much at all.
The post above recommends that garbage CCCP codec package crap... Windows 7 does all that stuff natively except Real Media support - don't fuck up a system (ok, potentially fuck it up) by installing shit that is simply not necessary and has been proven to cause problems in some situations. Windows 7 can handle that stuff itself; only MPC-HC and maybe Haali's Media Splitter can improve things, anything else is going to (potentially) cause problems.
See what I'm saying?![]()
Very good starting point is http://www.ninite.com![]()
Drivers
Windows update
DirectX Web installer http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
Microsft Security Essentialshttp://www.microsoft.com/security_essentials/
I have a larger list of open source/free ware that programs that are useful which I use, but those are really more preference oriented depending on what you need.
That's why you keep a flash drive labeled as INSTALL, and put your drivers and apps on there. That way, anything important to you is readily available.I just need peoples list of these so I can remember my own![]()
Make sure you read the last two posts. You don't need to worry about redirection anymore, nor does it really make sense, unless you reformat often...which isn't the case with Windows 7. Libraries work quite well, and if you put in place a good backup process, you don't need to worry about losing any data.The next time I install Win7, I'll be making a separate system partition as described in this thread. I wish I'd known about that before I installed.
Ninite does a poor job of correctly installing applications as well, in my experience. I can't recommend it.They dont let you pick any settings during install.. id avoid these.
Good to know because I was considering using it. I install quite a few of their supported apps anyway, but if I can't pick any options (hello unwanted toolbars), then forget it.Ninite does a poor job of correctly installing applications as well, in my experience. I can't recommend it.
