Frequent GPU errors in Win 7
APOLLO
[H]ard|DCer of the Month - March 2009
I am running Win 7 64-bit on several systems with GPU2 clients. The one thing they have in common that I never see in Win XP is a GPU error that makes itself evident very frequently. The error line is:
Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
Anyone ever see this message before? It occurs so often that I have become accustomed to ignore it, but noticing that my apparent production does not seem to correspond with what is reported in the stats, I'm wondering if this error is more serious than I had previously thought. My WUs complete and upload successfully. This error surfaces after the 100% and "successful run" lines, which is the reason I had ignored it.
If anyone knows or has an idea what this error might be, I'd really like to hear it. I could post the portion of the log that leads up to this error if need be, but there doesn't appear anything out of the ordinary except for that error line. :confused:
Is the app directory under one of the Program or System folders? I've heard that can cause trouble because Windows doesn't like those being futzed with unless it realizes you're installing something.
I have mine installed in C:\[f@h folder name]....maybe that's an idea if yours could be in one of the "protected" folders.
im guessing you are using the console version? if so make sure its in your root folder (C:\) otherwise you have to set it to run in admin mode.. not totally sure if thats that exact reason since UAC is the second thing i turn off after installing windows 7..
I'm using the console version and the clients are installed in their own folder in the root directory.
try running them in admin mode and see if that fixes it.. ive never used the console client so i have no clue other then that.. have always used the system tray client..
I tried running the clients as administrator and there is no change.
only other thing i can think of is delete everything and reinstall the client.. or try deleting your work folder and config file..
My Win7 64 box does this as well from time to time but all the WU upload ok and the points seam to be correct so I do not know whats going on with the log file.
Some WU do it and some don't it's not just one series.
Here are exerpts from 3 WU, one read the log file, one poped the error and one did not read the log file but did not pop the error.
All uploaded ok.
1st
[21:37:51] Completed 100%
[21:37:51] Successful run
[21:37:51] DynamicWrapper: Finished Work Unit: sleep=10000
[21:38:01] Reserved 84780 bytes for xtc file; Cosm status=0
[21:38:01] Allocated 84780 bytes for xtc file
[21:38:01] - Reading up to 84780 from "work/wudata_07.xtc": Read 84780
[21:38:01] Read 84780 bytes from xtc file; available packet space=786345684
[21:38:01] xtc file hash check passed.
[21:38:01] Reserved 25248 25248 786345684 bytes for arc file=<work/wudata_07.trr> Cosm status=0
[21:38:01] Allocated 25248 bytes for arc file
[21:38:01] - Reading up to 25248 from "work/wudata_07.trr": Read 25248
[21:38:01] Read 25248 bytes from arc file; available packet space=786320436
[21:38:01] trr file hash check passed.
[21:38:01] Allocated 560 bytes for edr file
[21:38:01] Read bedfile
[21:38:01] edr file hash check passed.
[21:38:01] Allocated 16454 bytes for logfile
[21:38:01] Read logfile
[21:38:01] GuardedRun: success in DynamicWrapper
[21:38:01] GuardedRun: done
[21:38:01] Run: GuardedRun completed.
[21:38:05] + Opened results file
[21:38:05] - Writing 127554 bytes of core data to disk...
[21:38:05] Done: 127042 -> 116296 (compressed to 91.5 percent)
[21:38:05] ... Done.
[21:38:05] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[21:38:05] Shutting down core
[21:38:05]
[21:38:05] Folding@home Core Shutdown: FINISHED_UNIT
[21:38:09] CoreStatus = 64 (100)
[21:38:09] Sending work to server
[21:38:09] Project: 6600 (Run 10, Clone 537, Gen 250)
[21:38:09] + Attempting to send results [October 16 21:38:09 UTC]
[21:38:10] + Results successfully sent
[21:38:10] Thank you for your contribution to Folding@Home.
[21:38:10] + Number of Units Completed: 3859
[21:38:14] - Preparing to get new work unit...
[21:38:14] + Attempting to get work packet
[21:38:14] - Connecting to assignment server
[21:38:15] - Successful: assigned to (171.64.65.61).
[21:38:15] + News From Folding@Home: Welcome to Folding@Home
[21:38:15] Loaded queue successfully.
[21:38:16] + Closed connections
2nd
[23:31:56] Completed 100%
[23:31:56] Successful run
[23:31:56] DynamicWrapper: Finished Work Unit: sleep=10000
[23:32:06] Reserved 85572 bytes for xtc file; Cosm status=0
[23:32:06] Allocated 85572 bytes for xtc file
[23:32:06] - Reading up to 85572 from "work/wudata_08.xtc": Read 85572
[23:32:06] Read 85572 bytes from xtc file; available packet space=786344892
[23:32:06] xtc file hash check passed.
[23:32:06] Reserved 25248 25248 786344892 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[23:32:06] Allocated 25248 bytes for arc file
[23:32:06] - Reading up to 25248 from "work/wudata_08.trr": Read 25248
[23:32:06] Read 25248 bytes from arc file; available packet space=786319644
[23:32:06] trr file hash check passed.
[23:32:06] Allocated 560 bytes for edr file
[23:32:06] Read bedfile
[23:32:06] edr file hash check passed.
[23:32:06] Allocated 0 bytes for logfile
[23:32:06] Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
[23:32:06] GuardedRun: success in DynamicWrapper
[23:32:06] GuardedRun: done
[23:32:06] Run: GuardedRun completed.
[23:32:07] + Opened results file
[23:32:07] - Writing 111892 bytes of core data to disk...
[23:32:07] Done: 111380 -> 110812 (compressed to 99.4 percent)
[23:32:07] ... Done.
[23:32:07] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[23:32:07] Shutting down core
[23:32:07]
[23:32:07] Folding@home Core Shutdown: FINISHED_UNIT
[23:32:11] CoreStatus = 64 (100)
[23:32:11] Sending work to server
[23:32:11] Project: 6606 (Run 7, Clone 399, Gen 389)
[23:32:11] + Attempting to send results [October 16 23:32:11 UTC]
[23:32:12] + Results successfully sent
[23:32:12] Thank you for your contribution to Folding@Home.
[23:32:12] + Number of Units Completed: 3860
[23:32:16] - Preparing to get new work unit...
[23:32:16] + Attempting to get work packet
[23:32:16] - Connecting to assignment server
[23:32:17] - Successful: assigned to (171.64.65.61).
[23:32:17] + News From Folding@Home: Welcome to Folding@Home
[23:32:17] Loaded queue successfully.
[23:32:18] + Closed connections
3rd
[08:16:08] Completed 100%
[08:16:08] Successful run
[08:16:08] DynamicWrapper: Finished Work Unit: sleep=10000
[08:16:18] Reserved 146712 bytes for xtc file; Cosm status=0
[08:16:18] Allocated 146712 bytes for xtc file
[08:16:18] - Reading up to 146712 from "work/wudata_02.xtc": Read 146712
[08:16:18] Read 146712 bytes from xtc file; available packet space=786283752
[08:16:18] xtc file hash check passed.
[08:16:18] Reserved 22248 22248 786283752 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[08:16:18] Allocated 22248 bytes for arc file
[08:16:18] - Reading up to 22248 from "work/wudata_02.trr": Read 22248
[08:16:18] Read 22248 bytes from arc file; available packet space=786261504
[08:16:18] trr file hash check passed.
[08:16:18] Allocated 560 bytes for edr file
[08:16:18] Read bedfile
[08:16:18] edr file hash check passed.
[08:16:18] Logfile not read.
[08:16:18] GuardedRun: success in DynamicWrapper
[08:16:18] GuardedRun: done
[08:16:18] Run: GuardedRun completed.
[08:16:19] + Opened results file
[08:16:19] - Writing 170032 bytes of core data to disk...
[08:16:19] Done: 169520 -> 168054 (compressed to 99.1 percent)
[08:16:19] ... Done.
[08:16:19] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[08:16:19] Shutting down core
[08:16:19]
[08:16:19] Folding@home Core Shutdown: FINISHED_UNIT
[08:16:21] CoreStatus = 64 (100)
[08:16:21] Sending work to server
[08:16:21] Project: 5781 (Run 0, Clone 417, Gen 244)
[08:16:21] + Attempting to send results [October 17 08:16:21 UTC]
[08:16:23] + Results successfully sent
[08:16:23] Thank you for your contribution to Folding@Home.
[08:16:23] + Number of Units Completed: 3864
[08:16:27] - Preparing to get new work unit...
[08:16:27] + Attempting to get work packet
[08:16:27] - Connecting to assignment server
[08:16:28] - Successful: assigned to (171.64.65.61).
[08:16:28] + News From Folding@Home: Welcome to Folding@Home
[08:16:28] Loaded queue successfully.
[08:16:29] + Closed connections
I do not worry about it because I have not had any EEU in a long time.
The card is a 9800 GTX+ with the latest drivers.
do you guys have your clients setup to accept WU's larger then 10mb?(required for GPU2 but not needed for gpu3) if not you might want to set it to accept them..might be whats causing the problem but its just a guess..
