Freezing & Strange Sound!
Lukehluke
Hi,
I recently upgraded a lot of hardware inc motherboard.
I sometimes now seem to get on either playing games, playing DVD's or listening to music.
It's not all the time but it has happened when doing those things.
It just freezes for a few secs and make a strange looping sound.
I did a Defrag or two drives and an error check.
I also use Windows 7.
When I got all the new hardware, I did a fresh install.
It didn't start happening till a week or so after.
Also I have a duel core and I am using Folding@home on both.
I would try reeinstalling your CPU cooler including removing and reappling the thermal paste since a crooked heatsink is a common issue.
If you still have issues try booting into bios and observe your temps and hardware profile.
Could it be that one of the things that I took from the old comp was the power supply and I have to many things connected to it?
I have the following:
Duel Core Processor.
3 Fans.
2 x Hard Drives.
Wireless Card.
Motherboard.
Graphics Card.
I think thats it lol
I have an attached a screenshot of the fan monitor program that I found when I am running a few programs.
Thank you for the list but I would need to know at least the model numbers of the parts and your power supply to make a judgement call. I am mostly concerned about these:
1. power supply
2. videocard
3. processor
Anything overclocked?
These are the models that I know of:
AMD X2 DUAL CORE AM2 ATHLON 64 4400 2.3GHZ 2X512 SOCKET AM2 - OEM
ASUS M2N68-AM - SOCKET AM2+ - GEFORCE 7025 - DDR2 1066/800/667/533 - SATA - RAID - GIGABIT LAN -MICRO ATX
MDT MD2500KS-00MNB0 ATA Device
WDC WD1600JD-75HBB0 ATA Device
SAMGSUNG CDRW/DVD SM-352F ATA Device
U.S Robotics 802.11g Wireless Turbo Adapter.
ATI Radeon X300SE
I use Folding@home which uses any spare CPU and keeps it at 100%'ish, so comp is never idle.
After looking at your list, unless you are using a really cheap power supply, it is not likely you have too many parts. 53c while folding@home running is a good temp.
The power supply came from a 4 odd year old Dell Dimension 8400.
Any ideas on the problem then as I have no clue?
Well since you seem to have issues with dvds, music and games, the easiest thing to do is to swap out your dvd rom. If that does not solve the issue, I would look to swap out your power supply.
Are you using onboard sound? If so, try disabling the audio in the BIOS and then see if the issue reoccurs (obviously you won't be able to hear anything, but if the audio chipset is the problem, then the freezing will go away).
It's not the DVD player as music & games comes from the hard drive.
What would it be called?
I can't seem to find it for some reason.
Select the Advanced tab in the BIOS, go into Chipset, then into Southbridge Configuration, and then set the AZALIA AUDIO setting to Disabled. That should do it.
On Asus boards you can find the onboard sound chipset by selecting onboard devices configuration. The onboard devices configuration on my Asus board is in Ai Tweaker.
That's usually the case, but this board is different. I looked up the manual, and the setting is in the location I mentioned in my post above.
Tried that.
Still does the freezing.
Could it be the Folding@home as I think it did that after I used that?
If you're using the tray client, there should be a slider to control CPU usage in the Advanced tab of the Configure window. If you're using the console client, you'll have to go into configure mode and set the CPU usage in the advanced settings.
well the problem is windows seven itself, i used it for a week and there were way too many problems when i used it. its has so many hardware incompatibilities, i just went back to my vista.
Long time no reply but I personally think its a heating issue as it seems to do that more when its hot but sometimes it does it when its cold.
I removed F@h and so the temp and CPU decreased but it still does it.
