Freezing Issue w/ Vista 64
I'm having a few problems with my new custom built system.
Here are the specs:
Intel DP35DP Motherboard
Intel Core 2 Duo E7200 2.53GHz
2x 2GB Crucial DDR 2 RAM
2x 1GB Crucial DDR 2 RAM
PNY GeForce 9600GT
2x Seagate Barracuda 7200.11 750GB HDD in a RAID 0 config via the mobo
Antec 650w Earthware PSU
Vista x64 Ultimate
A couple weeks ago, I put everything I have together and installed Vista 64 on my rig. Shortly after installing, every so often my system would freeze for about a minute at a time. Can't move the mouse, status bars stop moving, can't bring up the task manager. After about 30 seconds to a minute, it unfreezes and everything runs fine. In fact, it seems like the keystokes/mouse movements that were made during the freeze try to "catch up".
While installing all my drivers, the system reported a SMART error during a reboot. I figured I had a bad drive and was going to send it back. However, apparently Seagate was having issues with the firmware on their Barracuda drives. I updated the firmware and the SMART errors went away.
After this, I cleared my RAID array and recreated it and reinstalled Vista. However, the system is still having the freezing problems.
I can't seem to find any consisteny to when it happens; it seems to be completely random. I ran memtest and Seagate's drive tools with no errors found. I swapped out the 9600GT with another vid card that I have and still had the problem. I updated the chipset driver.
I've never used Vista 64 prior to this. Has anyone else had this issue?
Thanks for any help you can give!
I was having the same problem with my system too and i'm also running Vista 64 Ultimate. In my case, I discovered my new WD640 hard drive had some bad clusters. Now I have a new drive and I haven't got another freeze so maybe the drive was the culprit. But other peolpe suggested that it was a bad or underpowered PSU, or maybe a bad stick of ram. I'm still going to run memtest tonight just to make sure. Good luck.
