Freeze during boot sequence
natpond
THis is a slight repost, but last post got moved to HD forum, which i dont think was the issue, i just mentioned some HD stuff in the beginning that was not necessary.
Heres my problem, after it finishes the initial boot sequence (lists the processor speed, amount or ram, all the installed HDs, etc) then goes through the RAID boot up screen (which i am not using) it goes to the "PCI device listing" and it lists all the drives and their IRQs and all that, but it usually goes on to either boot up, or tell me an OS is nto installed. now, it just stay there, and after about 2 seconds, random squares turn black, so for instance where it said "IDE" before, now it will say "I_E" where the underscore is now, there is a blank, black space. so after the squares, or letters disapear, it just sits there with the little underscore in the bottom right corner blinking.
Any ideas?
Nat
