FreeNAS/ZFS pool hot plug question.
Phantum
I've been Google'ing all day and have come up with nothing, maybe you folks can help me out.
So I've got an LSI 9211-8i in my FreeNAS box, connected to a Rackable SE3016. This unit houses 8x 3TB WD Reds and acts as my local 'archive' pool. All data here is then pushed to Crashplan using the plugin. What I'd like to do is bring this pool up once a week, rsync the data from my other pools to it, push it to Crashplan and then turn the rackable unit back off until next backup all without bringing the whole NAS down.
So how should I go about this? Do I have to export the pool every time I want to power off the unit? Then import the pool, do the backups, turn off the plugin, export the pool and turn the unit off? Or do I really have to bring the whole thing down just to turn off the unit and then bring it all back up? This 'archive' pool doesn't do anything that would require constant uptime and isn't accessible to any user other than root, which runs the rsync operation.
EDIT: I realize that by not exporting the pool FreeNAS will complain about the "missing" pool but it's not really a big deal because this pool isn't required for day-to-day operations. I've also tried connecting this unit to a FreeNAS guest on my ESXi box with pass through however I quickly realized that the performance of the rsync operation from the pools on my bare metal box to the guest was abysmal so that's out... unless anyone has any ideas on how to clear that up.
I can't really comment about FreeNAS/ZFS, but I can offer some insight to rsync.
rsync is slow. Really slow. It's convenient, but doggedly slow - it's main strength isn't file transfer speed, but in reducing required bandwidth and being super easy to implement script-side. You can speed it up somewhat by reducing the connection encryption type (it defaults to using SSH normally), or switching to something else like SCP.
If your just updating a small percentage of your data set, rsync may end up being ok after the initial data copy. But if large amounts of data are changing on your weekly backup, you may be better off using another tool than rsync.
Thanks Brian, I've actually come up with a number of tests (based on your thoughts here) that should help me target the underlying cause(s); such as VM misconfiguration, hardware/driver, bandwidth availability, software (rsync maybe), etc. So I'm organizing and outlining a procedure now. However I can tell you that I've never experienced the level of slowness over gigabit Ethernet that I'm seeing now; avg. 20MB/sec
If you are going from ZFS to ZFS you should be using ZFS send/recieve.
Yes, ZFS to ZFS however the ZFS send/receive method is for snapshots. I want the data on my 'archive' pool to be the raw files, so I can pick and choose individual files upon restoring. This is a conscious choice and I'm doing it this way on purpose. Essentially the end result is the same but the method to achieving it is different. :D
Why can't you take a snapshot now and then just use cp or whatever to copy it all to your backup server and then from there on out take another snapshot and then use zfs send/recv whenever you want to update your backup copy with the changes since last snapshot.
There's no reason I couldn't do that, but frankly it sounds a bit more complicated than a simple rsync operation.... And it's outside the scope of the issue at hand.
I made a similar post over at the FreeNAS Forum and the closest consensus reached was; turn off the plugin, export the pool, turn off the Rackable unit. At next backup cycle; turn the Rackable unit on, import the pool, scrub, turn on plugin, backup to Crashplan, repeat. We know that the SAS expander is hot-plugable but what we're not positive about is proper procedure for pool/system integrity of an 'external' pool, that isn't required 24/7, to 'pop' in and out of the system without bringing the system itself up and down.
