Thanks
Change close window to NEVER
Although that won't fix your problem, it may give us a hint as to what is going on.
Looks like I am doomed
http://img210.imageshack.us/img210/4812/puttyinfo.jpg
Thanks
Warning: The following can be a security risk
I suggest you follow this guide
http://pcwizcomputer.com/index.php?Itemid=47&id=74&option=com_content&task=view
So you can enable root logins and thus we can bypass any of this username allowed business / 'su -' business.
Edit: alternative #1, just a diff link same procedure
http://freenas.org/documentation:setup_and_user_guide:services_ssh
Yes and please tell us the output of the follow
# zpool status -v
# zpool list
zdb -l /dev/da0
try that.
In PuTTY, just select text then it is copied to your clipboard automatically. Then paste in the postbox here on OCP.![]()
Alright FreeNAS doesn't have the zdb library; its stripped down to be smaller in size.
Maybe a stupid question, but have you tried rebooting the system? I would be curious if that changes anything to the command output (zpool status being the most important one; that should list your array).
Looks like maybe in order to import the destroyed pool I may need to destroy the pool with the unknown status, just a though.
Will this be too drastic?
How important is the data on your ZFS volume? If you really want it back, i can do it remotely if you set up a separate freebsd system disk, then i login and checkout your disks in native FreeBSD 8.
You could use most of the how-to guides on FreeBSD installation on my website, then open port 22 (ssh) on your router and forward it to the freebsd machine, then contact me discretely with the username and password. You can watch what i'm doing with the 'watch' utility; and we could keep in contact using IRC.
It would be some work on your end to set this up and connect only the FreeBSD system disk and the ZFS disks, while you have a second (windows?) based system to remain in contact and use PuTTY so you're logged in just like me and watch what i'm doing.
It does imply you trust me, of course. I wouldn't need to actually see your data, though. Just want to get the pool back up and mounted. Figure out what may have went wrong.
Yes, this is definitely a serious bug/issue on FreeNAS' part. I'm not sure what went wrong, but it's entirely possible that during the web-GUI expansion process some bug caused something to go awry.
I also feel i shouldn't recommend FreeNAS anymore, at least not for ZFS yet, until they release a well-tested version based on FreeBSD 8.0+ and ZFS version 13 or 14. They also have to test the GUI extensively.
If you're interested in FreeBSD, you can try the install guides (with screenshots) over here:
http://submesa.com/data/bsd
Once properly setup, it probably doesn't require you to do much maintenance, if any. You would use PuTTY as a command-line interface to the NAS; it doesn't really need a keyboard + monitor attached. But, of course, no nice web-GUI with FreeBSD. You would be running the 'production' version of ZFS, though. While the version in FreeNAS is still the older 'experimental' version; bugs still exist there that are ugly; though i'm unsure if your bug/issue originates from ZFS or FreeNAS' scripts, or perhaps both.![]()
I think your post is very well insightful
I am sure nbat58 could recover data (since he hasn't over written anything) but that would require perhaps some extra knowledge, nbat58 you can try the opensolaris forums / mailing lists
Obviously you already have a strong suggestion to go freebsd with those screenshots
I will always suggest opensolaris straight from genunix.org, get /dev right away -- works excellent headless as sub.mesa has said. Plus this way you're eating straight from the farm
genunix.org
Get b134, it's the latest installable pkg image
