- Aug 31, 2009
I'm getting 400Mbps writes on CIFS/samba but my FTP speeds to my FreeNAS in my sig is like 285Mbps. What gives?!?
You do realize he is using this on a local network...FTP blows
cleartext passwords = fail
I was referring to ftpes not sftp.sftp is just an SSH-invoked FTP client; i would not consider it FTP though it works similarly.
Try NFS. I could only get 40MB/s max using samba, but with NFS I get 80MB/s+.
Also, are you moving a few 8gb movies or millions of sub 10k files?
Because you are using SMB1, not SMB2, which fixes the 40MB/s cap, though it is only used with Vista/7 variants.
I just checked this out and xfered a 12Gig BR rip from my desktop to a CIFS share on my ZFS box (SE11) and averaged 102Mbyte/sec (value at the end of the transfer according to windows)? And CIFS is def. using SMB1.
Is NFS like CIFS where I can just open a window or do I need a specific utility to log into the box and download?
c:\>mount //server.ip.or.name/path/to/share T:
