FreeNAS and LDAP, what am I doing wrong?
jadams
Settings:
http://i.imgur.com/BmBAo.png
I obviously changed some info for security purposes. But its all pretty basic. I'm trying to import the users from the Built in Users folder in AD. The root bind DN is a user I created today whos also in the Users folder in AD Are my distinguished names correct?
The output from the console in the webadmin.
Code:
Mar 27 10:43:49 freenas freenas[1872]: Executing: /usr/sbin/service ix-ldap quietstart
Mar 27 10:43:49 freenas freenas[1872]: Executing: /usr/sbin/service ix-nsswitch quietstart
Mar 27 10:43:49 freenas freenas: Generating host.conf.
Mar 27 10:43:49 freenas freenas[1872]: Executing: /usr/sbin/service ix-pam quietstart
Mar 27 10:43:49 freenas freenas[1872]: Executing: /usr/sbin/service ix-samba quietstart
Mar 27 10:43:50 freenas freenas[1872]: Executing: /usr/sbin/service samba forcestop
Mar 27 10:43:50 freenas freenas: winbindd not running? (check /var/run/samba/winbindd.pid).
Mar 27 10:43:50 freenas freenas: nmbd not running? (check /var/run/samba/nmbd.pid).
Mar 27 10:43:50 freenas freenas: smbd not running? (check /var/run/samba/smbd.pid).
Mar 27 10:43:50 freenas freenas[1872]: Executing: /usr/bin/killall nmbd
Mar 27 10:43:50 freenas freenas: No matching processes were found
Mar 27 10:43:50 freenas freenas[1872]: Executing: /usr/bin/killall smbd
Mar 27 10:43:50 freenas freenas[1872]: Executing: /usr/bin/killall winbindd
Mar 27 10:43:50 freenas freenas[1872]: Executing: /bin/sleep 5
Mar 27 10:43:55 freenas freenas[1872]: Executing: /usr/sbin/service samba quietstart
Is there a log I can check?
Need some more information about the environment...
what is your domain?
what is the entire root bind string?
The picture does not work.
Entire root bind is for a test user I created for this, has all domain admin privs.
CN=nas,CN=users,DC=domain,DC=local
domain is simple domain.local
Base DN that I'm trying to import is simply the Users container.
CN=Users,DC=domain,DC=local
I'm not certain it actually makes a difference but you probably want --OU=Users,DC=domain,DC=local
Your pic isn't working but I can attest to FreeNAS working fine with my AD environment (in recent testing, I do not have it currently set up).
Updated the OP with a working link. Not much to it. Simply asks for BASE DN and ROOT BIND DN.
Root Bind DN is to a user "nas" in the main Users container.
This user has all domain privs. I even tried another known working domain admin and still no go.
Base DN I want to use just the Users container as well.
I've tried other combinations. The screenshot is just what happened to be in there at the time of the screenshot.
Firewall is off for testing purposes.
bump
is there something on the AD server I have to do?
I have a web application authenticating through ldap just fine.
