Aha! I may have a clue what the problem is; it could be the new memory tuning while installing Root-on-ZFS; i did not test this functionality because my VM has only 2GB RAM and the memory tuning doesn't work then. Could you try Root-on-ZFS installation and de-select the Automatic memory tuning checkbox at Step 4?
If that solves it, then i can fix the issue. ;-)
Yes! Unchecking the memory tuning fixed the problem (This system has 8GB, by the way). I left everything else the same, and it came right up. Also, /boot/loader.conf is now populated with lots of options. Before, it was completely empty, and the System->Tuning form wasn't working right either (i.e. you could enter a change and click "Save Changes", and the form would just come back blank again.
