lizardking009
- Nov 18, 2005
A few weeks ago, I was evaluating ZFS on FreeBSD 8.0 on ESXi 4. After working with it for a bit, I managed to get it running acceptably as an iSCSI target. When I turned on ZFS compression, performance took a major hit and worse, the entire VM would pause for several seconds.
My problem is essentially identical to this thread:
http://lists.freebsd.org/pipermail/freebsd-fs/2009-December/007343.html
In the case of the above thread, the author is also running FreeBSD on ESXi probably in a single CPU configuration.
Has anyone tried ZFS compression on a reasonably powerful hardware box - dual core or better? How was the performance?
I'd try, but I lost my spare hardware box... a Core 2 Duo doesn't get to sit around undeployed for too long.
