I'm a total Linux/BSD/Whatever newbie, and I'm running into problems. I'm following the instructions on this page: http://www.grpl.org/ism/install.html#freebsd.
Its been smooth more or less untill I get to the part that says:
Manually installing modules:
You'll need the following modules, installed in order. After expanding each archive, the process will be to change into the expanded directory and issue:
# perl Makefile.PL
When I type in "perl Makefile.PL", I get an error that says "Cant open perl script "Makefile.PL"; No such file or directory."
Can anyone help? I'm in over my head.
# perl Makefile.PL
