bigdogchris
- Feb 19, 2008
I'm on Windows 7. I have several folders on my system that I want to be able to Sync to a USB drive. I would use Windows Backup but it backs up periodically and the drive I'm backing up to is not always on.
What I want to end up being able to do is turn my external HDD on, press the sync button, sync folders, turn external HDD off. So I need something that will hold the sync between the folders I select and a removable device when it is turned off. Either something in Windows I'm missing or something to download. The drive is just an enclosure I added a HDD too so this isn't a packaged deal that came with software.
Thank you.
PS Windows Sync will not recognize this drive so I can't use that. I also don't appear to be able to use Offline files for a USB drive (or at least this one).
Thank you.
