Free mousepad through artscow
devkinetic
xpost from reddit http://www.reddit.com/r/gaming/comments/yxqi7/so_my_free_mouse_pad_finally_arrived/
Relevant links
http://pastebin.com/LePyBSiC
Basically, you apply someones code and it brings your order to 99 cents. When someone uses your code you get $1 credit on your account which you can type in the payment area (only after you've received the credit, otherwise it doesn't show). then your order is free. Only one person has to pay 99 cents to get it all started.
I don't have the ability to monitor the thread and post links like the dropbox one, so please just handle this in the thread, maybe someone else wants to take the helm. Once the thread is going on its own, i will post my own link to be fair for everyone else (not going to put my code in the OP)
Sounds too pyramid scheme-y for my taste.
There are a ton of free things. Click my account and go to credit and discounts.
Used to be called artsnow, their mousepads take like 3 weeks to get to the US but they are of really good print quality, it's not like some shitty heat pressed on image, the image feels like it an original manufactured item, high quality stuff I recommend them if you like custom mousepads.
Why did they change their name?
Hmm actually it seems they are a different site. But I remember artsnow saying they changed their name and their website forwarded me to artscow but artsnow still exists. Can't say if they are using the same manufacturer though, weird.
Hopefully they don't QC my mouse pad.. my friend is going to be seeing a nasty goat on his bday. :D
Totally shady.
