free dual screen wall papers???
doug_7506
ive been searching and i cant find them.... anyone know where i can get some that are at least 3840 x 1200?
thanks
doug
i tried google but not one of them gave me any decent site for dual screen they all charged...
i see at that site you have a picture for the right and left monitor, how do you place a pictrue in the background for each??? i really like that site but i dont know how to put a picture in the background on one wiht out doing the other...
im using vista 64
thanks
I run two monitors right now, both 1280x1024. There are very few dualscreen wallpapers, if you want two different ones on each screen what i did was attach two 1280x1024 wallpapers which made it like 2560x1024 (in microsoft paint which was a pain) and i set the desktop wallpaper to "tile" mode.
Using Ultramon, or DisplayFusion (free), you can have different wallpapers for each monitor. Otherwise you will need to do as above, and combine the images into 1 big image.
Some other sites I found w/ free wallpapers from a google search:
http://browse.deviantart.com/customization/wallpaper/multidisplay/?order=9&alltime=yes
http://www.dualmonitorbackgrounds.com/
http://www.dualscreenwallpaper.com/
http://www.e-wallpapers.info/category/multi-display/
http://www.ihateaol.co.uk/misc/dual_monitor_wallpapers/
http://interfacelift.com/wallpaper/
http://www.pixelgirlpresents.com/desktops.php?cat=dual
http://www.dual-display.com/pages/wallpaper.php
Finding multi-display wallpapers is pretty easy. The biggest problem I am having is finding them in high resolution for my dual 24" monitors (1920x1200 * 2 = 3840x1200) here at work.
im running at 1680x1050 so im having the same problem too... everything is 2560x1024....
thanks for everyhton that has replied so far!
i need 3360x1050
doug
Does DisplayFusion support specific monitor launching of applications like Ultramon?
