Freakin cable management..
virtuexru
Freakin cable management is my only big issue right now.. My case is pretty small and tight so wires are a pain in the ass. The main problem is that my mobo, the 20 pin connector to it is on the left side (Under the PSU), so it makes everything look messy because I can't re-route it through the back. Also, is there any "extensions" I can get to make my wires a little bit longer so I can re-route them w/out losing power efficiency?
Here is a picture of the problem below :
note* the 20 pin connector on the left (that is one of the FATTEST wires).. also note the minimal space between the bottom of the CPU to the mobo.
Thanks for any help in advance.
well..... i think you can easily extend those power cables by cutting them in half, add a similair kind of cable. Perhaps its also a good plan to sleeve the cables, whereever you can...
thats about it as far as i can help you..
Perhaps you can make a photo of your case, so we can see how it looks (open, ofcourse)
you can zip-tie the cables up and use mounting posts to secure the cables to the case. sleeing them is not a bad idea either.
