Atwooooood
- Oct 28, 2009
Is there any reason why the framerate counter in the corner disappears with resolutions under 1280x768? My native revolution is 1920x1080 if that helps. Any solutions would be appreciated.
Can you define what opengl & d3d is Nytegard
just updated to latest version 3.2.3. The corner of the counter shows up for a short while, then disappears.
edit: so i tried some lower resolutions and it shows up in full screen mode, just not the one i want which is 1280x720.
Could my monitor have anything to do with it? Samsung syncmaster 2333 16:9 1920x1080 native
