So began the dreaded Windows Home Server build. The reason I dread it is because I knew it was going to be an all-day affair. The actual build is not the time taker (though it was time consuming as I wanted to make sure it was done clean and right), but the loading of the OS, the gazillion MS updates and restarts, then the set-up time for the server once everything is installed, then configuring all the PC's in the house and the list goes on - thus the dreaded but very necessary install of the WHS began........Frank is happy though, he is shredding his file storage/serving duties now as the WHS will take over these tasks as well as taking/storing back-ups of Frank and the other PC's in the house. The dual 4-Bay external storage SATA drives I had attached to Frank will now be attached to the server, reducing issues I was having with Frank trying to handle everything he had attached to him. Though the EVGA X58 Classified board is a beast, it does have its limitations and is not optimal as a gaming/graphics laden box which is also maxed out with HDD’s and trying to be a file storage/server as well – it’s one or the other and Frank was throwing a fit (BSOD’s daily) due to not enough buss bandwidth to handle everything, even with increased voltages for the FSB.
So off I went to build the WHS and relieve Frank from his multi-functions as my gaming rig, server, file storage, graphics editor, etc and just bring him back to his main reason for being – work/gaming. So now on to the server build log……………….
NOTE: I said in the below image that this was a Q9400, it is actually the Q9450 CPU. I realized that once I kicked in Hardware Monitor to make sure the temps in the case were acceptable. Thankfully everything (even being OC'd to 3.0 on air) is operating now at 45c-51c - but on to the build log........
