threadbane
- Oct 28, 2005
I ordered a Fragbox 2 on March 29 of this year and received the unit in early May. Absolute joy until I realized the system would crash at random times while in full screen 3D, just as did the subject of the review did, only I was playing World of Warcraft or Unreal Tournament 2003 or 2004.
Failures could be 15 minutes apart or greater than 8 hours apart, making it very hard to know if an adjustment or tweak had made a difference. The unit was ultimately returned to Falcon on June 15. On July 17, the decision was made to rebuild the same CPU, memory, disk drives, sound card and optical drive into the Mach V case. The rebuilt system was finally received Aug 3 and has worked like a dream ever since.
There was definitely an odd problem with the 6800GT512 video card the Fragbox2 shipped with. Once warm, but not overly so, there would be memory corruption with distortion of meshes in space - I have some truly weird screenshots. BFG and Falcon both regarded that card as bad and it was replaced with the BFG 7800GTX in the rebuild.
I believe - and will always believe - there was an issue with the particular motherboard in that Fragbox 2 and will give an anecdote: I took a screenshot in WoW and saved it to disk. With WoW still running, from another PC on the same LAN I tried to copy that file across the LAN, first an open attempt into Photoshop and then using just Windows Exploprer. Both attempted file operations would crash and totally lock the Fragbox! Disabling the Audigy soundcard would correct this problem.
Do you suppose the motherboard I had was a unique dud and got built into the review machine
