Fractal R2 watercooled [pics inside]
Some days ago I started on watercooling a Fractal R2 PC, this is my 2nd computer to be watercooled and I'm much more happy with how smooth things went and how neat it is compared to my Haf 932 watercooled.
I was originaly planning on having the radiator internally but having it externa allows for slower fan and noise so having the heat get outside of case.
I did not get cpu block because it is not really necessary to watercool this cpu.
The air cooler is massive but I was able to nicely reroute tubing, with cpu block it would look more spacy ofcourse but also needs more pump power.
The pump and shoggy sandwich is not attached anyway to case, instead it is hold in place by the tubing, hopefuly this works OK.
Ive yet been able to fill it with water because I haven't figured out how to get my pump working, worst case scenarion I need to order a brand new pump and wait 1-2weeks.
