Fractal Node 202 Build Complete
wanakanabe
Finally got to finishing up my Fractal Node 202 build,pretty happy with the outcome.This thing is a beast.With the M.2 drive,it boots up to windows in like 8 seconds,amazingly fast!
No video but i did do pics all along the build.My first attempt at hydrographic dipping and am pretty happy with the way it turned out but it was a lot of extra work.I put it together and took it apart a couple times,figuring out the best way to route the wiring.The flat ribbon cable that came with the Corsair SF600 was pretty tough to deal with,so i separated all the wires,zip tied and taped them all up.I did put a 120mm Noctua fan up top in front of the 1080,blowing air into the case.
Haven't put it through the paces yet but from what i have read,heat has not been an issue.Doubt if i will overclock right away as it is pretty fast as it is.
Here is the link to the build!
http://s32.photobucket.com/user/Owump/library/Fractal Node 202 Build
