After nine years worth of delayed gratification, I've decided it's finally time to build myself an all new desktop. I'm going to start collecting parts over the next few weeks as I find deals. Tentative Parts List (Titan X as placeholder for GTX 1080)
I've been looking at the Node 202 as an interim case while I wait for the A4, but I have a few questions before I go on a shopping spree:
- I'm reading the Node 202 can fit two 120mm fans; are there any restrictions on width (either GPU or fan)? I was looking at Fractal Design's Venturi HP-12 PWM fans (25mm). The 202 is listed as 82mm wide, but is that actually how wide the interior is?
- I'd like to get an Intel 750 (2.5") to plug into the u.2 slot on the Impact. According to the Intel Specifications, it's taller than a standard SSD (~15mm). Will I have any problems fitting it into the SSD cage? I can't seem to find measurements for that on Fractal Design's website.
- This last one is more of a dumb question: does the SX500-LG come with the flat cable set I keep reading about, or is that a separate purchase? How helpful is the flat cable set in the Node 202?
