Raghav Narula
- Jun 13, 2016
Hi this is my fist post here. I'm a Comp Sci student looking to do my first serious build using server components to build a workstation/server for doing virtualization as well as experimenting with distributed systems like Hadoop, Spark, Mesos etc...
For this build, I've purchased a SuperMicro x9dri-ln4f+ which comes in SuperMicro's EE-ATX format. The main issue with this format is that the board extends above the I/O area by about 4cm. SuperMicro make multiple cases for this format but they are all either out of my budget, or are rack mount server cases, which are too noisy for my flat. So instead, I'm hoping that using a case designed to have room above the motherboard for water cooling might do the job with some Dremel hackery...
The pic below shows the issue.
I've got my eye on the Fractal Design Define XL R2, judging by the pics of it I can find online it looks very promising. If you own, or have access to one, could I possibly trouble you to take a quick measurement of the space available above the I/O area?
Thanks in advance for help!
