I've fitted an xfx gtx260 black in there (which I think is 10.5" or ~267mm?), with the top hard drive cage installed, and barely a millimetre or two to spare.how accurate are the fittings? video cards in pics that have been posted all seem... crooked.
Some pictures of my Define Mini + Asus Gene-Z
I can, as I've moved from the P180 Mini to the Fractal Case.
What's hot with the Fractal
- More room for expansion
- USB 3.0 Header
- Easier to cable manage
- Much more room generally for enthusiast hardware
- Plenty of ventilation
- External water cooling holes in the rear for when I pick up a Koolance 3K3UC
- Top mounted power button / USB etc.
- Amazing build quality
What's not.
- Some of the included thumb screws are a bitch to undo and re-do (Nothing major)
- Perhaps a bit more room could have been added behind the mobo tray
What's hot with the P180 Mini
- Was the only mATX case with all black interior at the time
- 200mm Big Boy fan in the top
- With some creative thinking, you could fit in 9 3.5" drives (I'm using the case for a server now with over 5 drives)
- Good build quality
What's not with the P180 Mini
- Gathered dust very quickly for some reason
- Plastic exterior
- Really hard to change hardware arrangement outside of what I had in there
- No pass-through for external watercooling
This looks to be perfect for my next case. Has anyone had any fit issues with a Hyper 212+?
Hey guys. I'm new here. I just switched over from a Corsair Obsidian 650d to the Fractal Define Mini. I love SFF computers. The 650d was just way too huge. I just wanted to share my case
Anyways I made some very minor modifications to fit an h100 in my case. I removed both HDD bay cages. I run my system off a lonely 128gb SSD so space was not an issue. I used a rotary tool to remove the bar between the 2 fans, and I removed 1 side of each of the plastic fan 'sockets' so they will fit exactly side by side, instead of having a gap between. Here are 2 pictures from the early stages of the build. I've ran into video card/mobo compatibility issues so I am not sure what I will be doing for a permanent solution for card. Might wait for the new generation to release.
I will get some more pictures up in the future. Next time I have to tinker with the machine I will get close up shots of the modifications I made in case anyone else is interested in doing the same. I am currently considering installing a window in the side of this little badboy.
The memory finally came. I took a few snaps of the final rig.
(You can't really tell easily in this picture, but there is about a <1mm gap between the memory and the cpu fan, so with this cooler your memory heat spreaders can be as ridiculous as you like.)
I've never been so stimulated by a computer before...
- Fractal Design Define Mini
- ASUS Maximus IV Gene-Z
- Intel Core i7-2600k
- Cooler Master Hyper 212 EVO 120mm cpu cooler
- 4x4GB G.Skill Ripjaws DDR3-1866
- PALIT GeForce 460 2GB
- OCZ 120gb Vertex 3 and Agility 2 SSD's
At first I was surprised at how loud it was - I was expecting it to be nearly inaudible but it was far from it. After I installed the ASUS AI Suite and dialed in the Fan Xpert to bring the fan speeds down (they were going at 2000 rpm) while the components are cool enough, it's much closer to that "inaudible" target I had in mind. I have the case fans spinning at 800 rpms, the cpu fan at about 900, though when I start up prime95 they instantly whip up to about 1300 and 1700 respectively and become noticeably louder, though not nearly loud enough to be annoying.
CPU Temp sits at about 24 degrees idle (1.6 GHz) and tops out at about 53 degrees while running prime 95 (4.2 GHz). I'm not a person who spends a lot of time thinking about case thermals, but I'm pretty impressed with how this case can deal with heat seemingly effortlessly with just the 2 stock case fans.
Still, I wouldn't mind going from my current "nearly silent" to "dead silent". Anyone have this case that can't hear it at all from more than a few feet away?
Amazing! Im building the same setup as you!! only difference is the Video Card
