Fractal Design Define 7 question.
FlipCody
I plan on replacing my Define R5 with a Define 7. If anyone has the 7 could you measure the distance from the rear of the case to the front of the front feet? I'm trying to figure out if the case depth/length is too large for where I plan on putting it. The R5 works but just. The 7 is about an inch (26 mm) deeper than the R5.
Thank you!
