MrGreenMan
- Feb 8, 2013
Hey Guys, thought I'd show a mod I did earlier this year which I thought was pretty cool. In the end it's fairly pointless as its running a 2390T which runs at 35w and a larger case would definitely be better for cooling. My only regret is that the 200mm fan isn't PWM-able without adding aditional hardware / cabling.
I modded an Array R2 to fit a 200mm fan for the intake as well as a Hyper 212 full size HSF. I'm bad at taking pictures but you can sorta see it below
The stock PSU rests below the empty drive bays and has an output below the case (had to strip a power cord and put terminal ends so it would clear the 200mm fan blades. I would have liked to have used 2 fans on the HSF but if (or more likey when) I decide to add storage, the cables will not fit on the drives. (maybe a 15mm fan will be some tight clearances)
Love the ZFS / ESXI all in one now.
