Fractal Design Arc Midi R2
HardOCP News
[H] News
The crew at Guru3D seem rather impressed with the Fractal Design Arc Midi R2 case. If you need a new mid-tower chassis, you might want to read this review.
This product is made with airflow and liquid cooling in mind to serve the more performance oriented PCs. Fractal Design Arc Midi R2 has many other features that we'll show you in this review, like cable routing space, removable fan filters, CPU cooler sizes limits of up to 170mm, a black paint and a top I/O panel with two USB 3.0 ports, audio in/out, power button, HDD activity led, reset button and fan controller.
It's a very good case; solid, minimalistic design, and most importantly the radiator mount on the top is offset to the opposite side of the motherboard tray to avoid hitting VRMs, etc.
