Fractal Arc mini R2 build, advice needed...
thercman
Hi everyone!
It's been 10 years since I have done a build so I would love some input.
My builds requirements:
1. I need to replace my old 2009 iMac. (staying with IOS, Hackintosh)
2. The computer will be used primarily for basic video editing, music production and to play WoW on. :)
3. My budget is about $1400 before shipping. (I am sure it will cost more, it always does)
4. It needs to be relatively quiet
5. I would like it to look custom but not break the bank.
I already have:
1. Fractal Arc Mini R2
2. Duel Corsair 120mm Quiet Edition intake fans
3. Duel Corsair 120mm SP Quiet Edition fans for a radiator.
4. Corsair CX750M power supply
What I am planning to buy: (needs to be Mac compatible)
1. Cooler Master Glacer 240L
2. Gigabyte Z87 LGA 1150 2 Way SLI mATX Motherboard
3. Intel Core i5-4670K Quad-Core Desktop Processor 3.4 GHZ 6 MB Cache
4. Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800)
5. EVGA GeForce GTX760 SuperClocked w/EVGA ACX Cooler 2GB GDDR5 256bit
6. TP-LINK TL-WDN4800 Dual Band Wireless N900 PCI Express Adapter
7. Blu-ray drive
8. Fan controller
9. GPU cooling block?
10. 2 - 22" monitors
11. Clear tubing with colored coolant and a small reservoir.
12. SanDisk Extreme SSD 240 GB SATA 6.0 Gb-s 2.5-Inch Solid State Drive,(for IOS) + (another SSD xxGB for storage)
So do you guys think this build will satisfy my needs graphics wise, or would you recommend another card under $300? To keep the fan noise down should I add the GPU block into the system? It seems like it will make a huge difference... My thoughts are to keep the intake and radiator fans at the lowest settings possible. I am not planning to over clock the system so I am hoping its doable...
