wahaha360
- Sep 8, 2012
Update 2019-04-09 : Slow, but not forgotten. Making prototypes using aluminum. Once designed finalized, will make POM version.
Update 2019-01-14 : Block Pump Prototype 1
A lot of you guys are familiar with the Swiftech Apogee Drive ii, but it's too tall (~66mm with fittings on one side, ~62mm on the other side) for a lot of the builds.
I have been working with a small shop to get a low profile (~48mm) CPU Block + DDC Pump + Res (maybe) combo that will work for the A4, C4, Ghost S1, M1, Mach One and Skyreach 4 Mini.
Renderings
Prototype
Renderings
Prototype
I'm working on Version 2 now, Intel Mount on top, AMD Mount on bottom.
