FPS in CS:S?
Timbowens
What are you guys getting in CS:S as far as FPS?
At 1600X1200, everything on low, sometimes I drop down to around 120 during firefights. Also, the longer I play the more..stutter ( I guess is what it is) I get. When I do the stress test I get 282.
It's the rig in my sig, and I've used the 158 and the newer drivers none of which make a difference.
Could it be a heat issue? I don't have the card OC'ed (besides stock) and according to Riva, it idles at about 70c. I don't know what it goes up to when I play. I've got the side off of my case so I know it's getting air flow.
I've done a reformat and I've used driver cleaner when i change the drivers and I'm using Vista 64.
Go to the release notes in the beta release 163.44 for nvidia.
In the known problems section there is something on 8800 series cards and CS:S being really jumpy. They have a fix for it......I cant remember what to do.
Last time I checked I was averaging in the 100's
I'm running an 8800GTX @ 2560X1600 8XAA and 16AF
I don't ever notice any lag or stutter.
I'll check it out, thanks!
