FPS help.
PoleVault
Im on an acer ferrari 4000 laptop. Ati mobility radion x700. With Omega drivers.
Im playing a game called warbirds and im trying to get the FPS rate up. No matter what i do the fps is maxed at around 62. So i figured there is a refresh rate cap. Im not very good with the settings but i looked around and all the stuff that says refresh rate overide is dissabled. I then looked at my Display>>>Settings. Under my primary display 1 it says "Max refresh 60". Is this what is keeping my fps maxed out at 60? If it is, is there any way to increase it or disable it? Also is this just my main display? in other words if i hook a different monitor up to it will i get a different refresh rate max?
Thanks for the help!!
um call me ignorant, but around 40FPS+ is considered very playable by most people in most games.
Is it going way below 60 sometimes or something?
this is a flying game so more fps is needed and also it drops over some runways and such. Most people who play this game try to get it to 100+
Check to see if your Vsync is on and if it is turn it off... It should increase the FPS. :)
