Who do you work for Drant?
Well, I can't speak for everyone, but I don't consider the ghosting that he posted in that video to be "minor". I can definitely understand that others won't be bothered by it, and I respect others' opinions, but for me personally, I find that type of ghosting to be incredibly blatant and annoying, and it's simply unacceptable for some of the applications for which I would use the monitor. I also saw one in Best Buy, and that type of ghosting was apparent just by moving windows around on the desktop. It was quite honestly one of the worst-looking displays in the store in terms of ghosting. My Dell 1905fp has a much slower response time than the Gateway, but I still find the ghosting less distracting because it doesn't trail different colors.The constant barrage of slams because of some minor ghosting is just kind of annoying, and quite frankly the display ghosts less then most displays I use at work (Dell 2407 included).
That's my thoughts on it as well. Some monitors can control it better then others but using that gray backdrop (I believe) can be seen on most (if not all) LCD monitors. If this is true then you are splitting hairs. Now if this happened regardless of the backdrop then yes, this is a major problem. Have you tried increasing your refresh rate to 70Hz? Some monitors have a high enough vertical/horizontal refresh rate were you can get away with it (check your manual). Then properly calibrate your brightness (backlit) and contrast and see how it looks then.That looks like the standard overdrive trailing I've seen on other monitors, except stronger on dark colors. Some monitors don't correctly compensate for overdrive when changing settings, so maybe some settings have stronger trailing than others.
Ferris, it seems obvious to me that you don't game on this monitor since only a blind a
person would not see the horrendous trailing it shows on every First Person Shooters. If
you have GTA San Andreas, set to night time and then look at the moon and move your
screen around, watch as the moon leaves a centimeter long shadow. For any
games with a skybox with stars, you'll see the ghosting very noticeably.
The reason I xxx'd out my responses because they were replied to or no longer
contributing to the topic. There are obviously too many useless posts clogging that
thread already.
It is more plausible that you are the one working for Gateway than I am an employee of
another company badmouthing a single monitor. If you want to know why I'm so
disappointed in the monitor, ignoring all its positive facets, and starting a coalition against
Gateway is because I have had four FPD2275W, which had intolerable backlight bleeding
on every model. The 22'' cost me $420 but this 24'', which I thought would be the end of
all my troubles, brought along even more with its banding, ghosting, and uneven lighting
at 90* view. These problems were not present on the 22'' and I'm just pissed off that I
paid $200 more for just the 2 extra inches. I went through two of these 24'' at Circuit City
and got more duds. Like you said, to keep trying, and as I did I went through the
Gateway's cross exchange and got yet another one with the exact same problems.
Of course, by the time I got the monitor through FedEx, the CC receipt has already
expired. I really tried to get used to the ghosting and I thought I could, but it's been a
more than a month.
Please excuse my pessimism with this monitor as I do not entirely loathe it. Here's my
review http://www.widescreengamingforum.com/forum/viewtopic.php?t=9338
To rephrase my point, I'm pissed off at this monitor because of the IG that was not
present on the 22'' but is now on the +$200 model, and I'm stuck with it. If there were no
IG or if I don't play games at all, then I would shower it with praises as you do, Ferris.
What I'm simply asking here is if this single most annoying problem with the 24'', the
inverted ghosting, is present on every FPD2485W in existence. Meaning there is
absolutely no chance I will get a model that won't do what the video shown. If everyone
says yes, then I will come into closure and be complacent with that fault. If however,
there is a godsent model like Ferris', I will keep trying to get it. By the way, I really would
like to ask you to show everyone how minute your ghosting is.
To the people with inverted ghosting: please call Gateway (on your monitor's box)
and tell them about it. I believe they make a list of the reported problems, so if more of
us tell them about it, they can stop classifying it as an isolated incident.
Also, how come no one has replied with their ghosting result? Set your main cursor to this
http://www.eggdisk.com/files/314892_ibdow/ghostcursor.zip and then move it around this
(gray background) forum and see if you have a long dark trail.
Who do you work for Drant? You XXX out all your posts in that Gateway thread then do nothing but make slams on this display. Even going so far as making a lame music video on Youtube based on this display.
My display has minimal "inverted ghosting" and no traditional ghosting. This display excels in so many aspects that a little smearing is not going to ruin it for many people. Sell it and get a new display dude, give it a rest.
There is no reason this couldn't have gone in the Gateway thread btw.
No offense,but I am starting to think you yourself work for Gateway.![]()
There are a lot of people asking about this issue in the monitor's main thread, but
answers are either vague or not given at all (they're just ignored and get lost in that huge
thread). Those who have the Gateway 24'' please do us with the inverted ghosting a favor
and test and reply if you have this problem, too (If you've been ignorant of it all along).
Use this cursor:
(Set ghostcursor.ani as your normal cursor)
Extract the zip to C:\WINDOWS\Cursors\
Control Panel -> Mouse -> Pointers tab -> click on "Normal Select" -> Browse -> Open
ghostcursor.ani -> Apply
My monitor has the banding as well. Also, it radiates some serious heat.
Interestingly, the banding (reverse ghosting) didn't appear until I used the monitor for about a week.
I've been able to reduce the appearance of the ghosting 60-70% by adjusting the contrast/brightness so it's not that huge of an issue.
The heat, on the other hand, is ridiculous. It feels like I'm sitting in front of a weird space heater/LCD monitor hybrid.
