FPD in scheme properties not available (ATI)
UFarch
I cannot get the FPD scheme in display properties (cat 4.6's on XP) to be usable. It is grayed out.
My monitor (vp171b) is correctly installed and recognized. I can only use an analog cable to get a signal from my 9700pro at the moment. DVI cable produces no image on screen. It was suggested to me that I use the FPD scheme in my display tab, but the bastard is grayed out :(
any suggestions?
You have to have the DVI cable connected for that option to work. I realize you said that the DVI cable gave you a black screen so I'm not sure what you could do. Maybe if you had a second monitor, any kind would do. You could set up dual monitors w/ the FPD as the secondary and once that option and display are working, switch the primary and secondary monitors then reboot and disconnect the analog monitor.
