FP241W vs FP241WZ
vengence
Level capped
I'm confused, what is the diffrence? I THINK I read that the FP241WZ has the new firmware that allows 1:1 mapping from the HDMI port, is that right? but then I also though I read the FP241W has the new firmware as well? So what is the diffrence?
If u buy this monitor, i would suggest to buy the newer revision and that would be the WZ. I dont know what are all the differences but one is, that the WZ has got a new technology which reduces ghosting and these things
When did it become so hard to just buy a new monitor :(
Get the W. The WZ has a different panel with an optional feature for reducing ghosting... it doesn't work very well so you're not really getting anything by paying that extra price for the WZ. If you plan to connect other devices to it, make sure you get one with the latest firmware...
This is completely false.
FP241W has newer firmware. It fixed all the problems with HDMI, VGA and component inputs.
Be sure to get the Sept 2007 build one. It said right on the box, so don't open it if it is not Sept 2007 build.
