FP241VW vs FP241W
lobski
Apparently the FP241VW uses an updated panel of the older FP241W... Yet is the FP241VW a better monitor than the FP241W? Digital Versus rates the FP241VW with a higher input lag. Which one would you guys recommend for someone being sensitive to input lag? FP241VW? FP241W? Neither?
They are likely the same, also the same panel. But I think right now you can only get the VW one. W is discontinued. The bad thing about VW is it can't shift up and down, but to most people it really doesn't matter that much, since this LCD is so big and you are going to view farther away from it. So up and down doesn't really matter. For me and many of my friends, we all like VW's style over W model. So we all end up buying VW. Hope this helps.
