Foxconn
bob
FOXCONN K8S760MG-6LRS with SiS 760 Chipset.
I cant find much on this motherboard, but its the cheapest microatx socket 754 on newegg. Im also interested in how this motherboards performace is, and what overclocking it can do. I also want to use it with a 250Gb Hitachi SATA drive, and ive heard people having compatability problems with larger SATA hard drives and motherboards.
Also, Is foxconn really #1 in motherboard sales? My friend keeps calling the board I want a peice of crap "off brand" because it doesnt have a fancy name. Ive seen a figure from the years end in 2003 for $10 Billion in motherboard sales. $10 Billion says quite a lot.
Edit: the $10 Billion figure was off. Here is a quote from the foxconn website " Revenue Reached 150,000 Million This Year. " So 150 Billion?
cheap isn't always a good idea..
SIS chipsets are not all that great.. I used to run one on my 2.2ghz I found it to be slugish and have small problems. The chipset is okay though, I didnt have MAJOR problems.
I'd suggest maybe MSI, ASUS, ABit, and a few others.
Also Foxconn makes other stuff. They practicly dominate the market on USB ports, and other ports. (their ports are good though, from what I've found)
Foxconn is Hewlett Packard/Compaq crap I know I use to Build PC's and laptops for them. If you want a incompatible POS then go for it, your better off spend a little extra ca$h if you want stability. After all they had a 61% fail rate on all their laptops... hehehe
enjoy!
What about that El-cheapo Foxconn motherboard thats selling for really low on Newegg... it started at $37, but now $39...
Specifications:
Supported CPU: Socket 478 Intel Pentium 4/Celeron Processor
Chipset: i845GV + ICH4
FSB: 400/533MHz
RAM: 2x DIMM for DDR 266/333 Max 2GB
Slots: 3x PCI
IDE: 2x ATA 100 up to 4 Devices
Ports: 2x PS/2, 1x LPT, 1x COM, 1x VGA, 6x USB2.0(Rear 4), 1x RJ45, Audio Ports
Onboard Audio: AC97 6-Channel
Onboard Video: Intel Extreme Graphics
Onboard LAN: 10/100Mbps Ethernet
Form Factor: MicroATX
It looks like a good deal to me so far, but I'm more concerned about reliability, if anyone knows by chance.
If a motherboard has an Intel chipset it doesn't matter who produces it or where.It will simply work.
This is the 1st rule when building an Intel based PC.always use an Intel chipset.
Yeah, when I saw that this board didn't have an VIA or other crap name chipset in it, I really looked at this board cause it looks like a hell of a deal...
