Foxconn P9657AB / memory compatability question
SuperJosh
Hi guys. I built a PC about 6-9 months ago and asked your opinions and you gave me great advice. Unfortunately about a month ago lightning struck my house and despite the best efforts of my surge protector my PC bit the dust. (well parts of it)
I am looking to try my hand at Vista now that SP1 is out and it seems to be looking like a real OS so I am looking at getting a new mobo and RAM to finish off my system. My CPU will be:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
Intel Core 2 Duo E6750 Conroe 2.66GHz
I am looking at this mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186116
Mainly do the ratings it got, the features and the price.
I am also buying this RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227269
OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
to make Vista run a bit smoother.
However I read in the specs for another mobo that "Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets. "* and that memory is 5-4-4-15 and 2.1v. I am guessing that I need to look at a mobo with another chipset, but I wanted to ask you all since I that seems like an extremely limited RAM timing to me.
Thanks, Josh.
*Source: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135022
