Foxconn P45A-S thoughts.....?
Aerixx
Hello everyone. I am looking to get a new (semi-budget) mobo to clock a Q6600 on and was wondering if anyone has any experience with, or comments on, the Foxconn P45A-S? I will be cooling on air and am not looking to set any OC'ing records, anything over 3 Ghz would be just fine. I will be running a 4870 card and want the capability to add another in the future for Crossfire. Can anyone tell me if this board will provide full x16 crossfire performance with two cards or is this a board that gives reduced bandwidth to the second card? Any and all comments are greatly appreciated. Thanks!!
I forgot to mention that this board is available on Newegg for about $110 including rebate and shipping. That's why I'm looking at this one but I'm open to other suggestions in this price range if you may have one. Thanks again!
I am posting from one. It was the easiest board I've set up as far as I required no tweaking to be up and running. I haven't started OC'ng yet.
P45 runs crossfire in x8/x8 mode, it won't be a problem though since x8 PCI express 2.0 isn't a bottleneck. You should be able to do 3.0GHz with that board at the least.
Thanks for the replies... This board sounds like it's worth a try. I'm presently stuck with an MSI P6N that won't budge off stock speeds. (And it cost me about $200 - errrr!) One of my main goals is to get Flight Sim X running better and I hear it depends greatly on the cpu speed. As long as I'm not losing too much if I upgrade to Crossfire, then this should be the next board for me. Thanks again for the info!
The ASUS P5Q Pro would be a good option if you can find it for around $140 and are willing to pay that much. The Gigabyte GA-EP43-DS3L and GA-EP45-DS3L are also great budget boards for around $100-115, although you'd have to go up to the GA-EP45-DS3R to get Crossfire support. The Foxconn is very solid from what I've heard though, so it would be a good choice as well.
Gigabyte makes nice boards as far as I've experienced them. I still have a great Gigabyte 7NNXP, used to run an AthlonXP 2500 clocked to 2.3Ghz. Nice board in its' time. Thanks for the other options. I'll look into them but so far the features, price and personal reviews of this Foxconn sound hard to beat. :cool:
