Foxconn NF4SK8AA-8EKRS Problems
RainofTerra
Are any users of this board having issues where you get a warning that the board is running in some kind of Safe mode and to "Please re-setting CPU Frequency in the CMOS Setup"? I am using the automatic settings with my X2 4200+ and I get this everything I boot. The board is running the latest BIOS but I can't find one later than one from early August. I hope that isn't the last BIOS update they plan on doing, otherwise I fear I may have bought a lemon. :(
Anyone experience this and have any solutions?
Thanks,
-Jeff
"To fix this issue, please update the BIOS again using the instructions
below:
This time update it from a bootable floppy diskette and follow the steps
below.
1. set the TBL jumper (next to the CMOS jumper) to Pin1&2
2. Use the parameters /py/sn/cc/cd/cp/wb to flash the bios from the A
prompt. For example...
AFU860H 538W1P26.BIN /py/sn/cc/cd/cp/wb"
Worked perfectly. Thanks to Foxconn support for their response.
Hopefully this will help someone else.
-Jeff
