Foxconn Arrive X48 Blackops
Holy crap, a tower for LN2 or DI! That's madness!
If used as a waterblock it looks more like a mini res with some fins.
But that's a board and another!
Hi m8 how you doing, long time & all:)
See your still on MSI even though you've moved to the dark side:LOL:
I want one of these suckers. Wish they'd make a 780i board with similar power regulation circuitry and cooling.
Memory slots are too close to the primary video card slot. Other than that, looks pretty good. The bottom PCIe slot will be useless for dual slot video cards. That's something that more companies are doing and I wish they wouldn't.
Pretty sure I joined the "dark side" after you my friend. :D
MSI been good to me. My last AMD board the K8N Diamond (long way from K8Neo-FR you helped me with) was a work of art and best mb I ever owned. This P6N is like a rock but doesn't do so well overclocking the quads. Way things are going it looks like I'll do an Intel chipset next time as well. Maybe this sweet looking Foxcon you've posted. My next build is going to be an all out effort with total watercooling. Currently only wc the cpu.
Yep i think so. I went this time last year.
Glad to see the boards are treating you right anyway:) I just get confused now by another Diamond board wish they'd get a bit more adventurous with their naming.. Last Nvidia chipset i had was 939, i'm hooked on intel now:)
Yep I'm pleased with water cooling , wife can hear the telly now:LOL: I 'm on gfx & Cpu atm, have done NB but on current board it's a non std fitting.
keep us posted, will look forward to seeing it.
luck:)
Well they can do it on a board outside of the case but look at the inside of your case or most other cases for that matter. It won't fit without a customized bracket.
No your right Dan_D , forgive my sense of humour was a bit flippant. There's also the matter of what header blocks the block as well. along the mobo edge.
