CaptNumbNutz
- Apr 11, 2007
A couple years ago I bought a Foxconn A7DA-S socket AM2+ motherboard. It worked beautifully for about 6 months.
The motherboard has built in power and reset buttons. One day the system hard locked during a game (not overclocked). I couldn't ctrl-alt-del out, nothing. Only solution was rebooting. I decided to shut down the system, so I held down the built in power button down for 4 seconds (or so I thought). I couldn't figure out why it wouldn't shut down, then I realized I was actually holding down the reset button. I then stopped pressing the reset button, and pressed the power button for 4 seconds and it shut down just like it should.
I then tried to restart the machine. The board, power lights, and cpu fan kicked on, but no post. No warning beeps, no video, nothing. I went through the usual gamut of troubleshooting, reset bios, remove battery, removed video card and tried onboard graphics, minimal hardware (1 stick of ram tried in multiple slots, no HDD) etc. I even tried out a Post Code diagnostic card that went into the PCI slot, and all it gave was random codes. According to the Post Code diagnostic card manual, this usually meant the board was dead due to some hardware failure.
Figuring the board was not worth the time to continue effing with it, I went and bought a new board. This foxconn motherboard has been sitting in a box for about 1.5 years now. I am hoping to resurrect it to upgrade one of my systems, or end up selling it cheap to a friend.
Here's what I want to know:
-What the hell killed it and why? Was it holding down the reset switch for 4 secs instead of the power switch?
-Is it repairable? Is it a dead bios which can easily be replaced by ordering a spare bios chip from Foxconn?
